cant get my heads off?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2006, 08:48 PM
89silverado454's Avatar
snowslinger
lol, i took all (14 total i think) bolts that line the top and bottom of my head then i took the 5 bolts under the valve covers off, now i cant pull this thing off! itwont budge!! what gives? did i miss somthing? its a 350.
Old 03-09-2006, 08:49 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
what you're missing are 3 bolts!
There are 17 on a SBC. Look under the exhaust manifold.
K
Old 03-09-2006, 08:57 PM
snowslinger
do i have to take my intake off to get the heads off? lol never taken an truck engine apart before..
Old 03-09-2006, 09:04 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Take the intake off, then you can remove the heads. The head should lift off but you may have to gently pry it up. Dont do it too hard because you dont want to damage the head gasket sealing surface... The engine is no different than one you might find in a car...It'll come apart the same way...
Yes the intake will need to come off as well.
Old 03-09-2006, 09:07 PM
snowslinger
oh ok, thanks.
went out and counted, 19 bolts hmmmm
starting to get dark ill take the intake and heads off tomarrow i guess.
Old 03-09-2006, 09:32 PM
57 Chevy's Avatar
Daryl
Location: Montana, now Arizona.Now Colorado. Wish I was back in Montana
Why are you taking the head off?
Old 03-09-2006, 10:20 PM
E.T. divided by $ spent= Speed
There should be 17 I believe head bolts and the intake has to go too.Then you'll need to pry the head off.Do so at the corners and make sure your not in a postion that will scare or chip the block or heads.
Old 03-09-2006, 11:04 PM
snowslinger
its an old 350 thats been sitting for about 10 years im just doing a bit of inspection, want to look at the cylender walls and whatnot
the extra 2 bolts i took are from the intake.
Old 03-09-2006, 11:24 PM
Wiki Edits: 3
lol, sounds like you've still got problems, the intake has 12 bolts!
K
Old 03-10-2006, 10:22 AM
johnsongrass1's Avatar
Race it, Don't rice it!
I thought it got dark for around six months in Alaska?
Old 03-10-2006, 08:20 PM
snowslinger
lol no only a few months dose it really get dark and thats when its light from 10am-3:30pm at the least... summer its light 24/7
now its 6:15pm and ts working towards sunset, wont be dark tell 7-7:30.
springs here! acually im on spring break as of today from school
WAAAY up north i hear it can be dark 24/7 at times in the winter... creepy sens i dont really like the dark
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
Which Heads to use? Mike_82 Engine 9 03-05-2009 10:32 PM
sbc heads shieldbreaker Engine 5 08-27-2005 08:12 PM
Heads and Intake combo black66 Engine 4 07-23-2005 11:33 PM
looking for some head(s) now i'm gonna explode! bullheimer General Rodding Tech 25 04-12-2004 01:16 PM
