Can't get my lokar trans cable to fit. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2003, 06:25 PM
Hey all.
I really need some help. I have a 1983 Ford F150 with a 302 and aod trans. I changed the intake and carb and now have to change my kickdown rod to make it shift. I bought the lokar cable for ford aod's. I've tried every way I know how to get this thing to fit. Following the instruction paper only produces interference. I called lokar tech support several times and we were not able to get it done. Is there anyone that has any knowledge on this one? Help would be grrrrrreatly apreciated.
Thanks.
Old 08-21-2003, 05:07 PM
Was the Lokar cable designed for your particular combination? You may have to modify your old rod setup to work.
Old 08-22-2003, 03:41 PM
I was told that the cable would (should) fit without any modification. This application is probably not as common as others such as with the mustangs. I'm going to try my best to make it fit well.
Thanks for the reply.
Old 08-22-2003, 04:23 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
What's not fitting?
