Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - can't get project journal to work so heres my rat rod build
Old 04-22-2010, 04:26 PM
matt167 matt167 is online now
Wiki Edits: 31
cut out the firewall..
removed 6" from the bottom and welded on bottom rail.. 1st welds my new welder welded..
bolted it on ( drilled and tapped frame )
built the lower body framework ( no pics ) and the front window framework
some pics got lost so.. skip ahead and the location has changed to my grandparents garage as it's easier to work around and they suggested it.
