Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - can't get project journal to work so heres my rat rod build
Old 04-27-2010, 04:22 PM
matt167 matt167 is online now
Wiki Edits: 31
well. I was trying to figure out my P-30 ( Chevy Delivery van ) gauge cluster and I kept hearing ratteling inside the cluster and eventully the glass was loose.. pulled it apart to find what was left of the rubber/ plastic bumpers that held the glass tight... fix was quite easy.. I replaced the plastic bumpers with clear silicone caulk, let it set up for an hour and then put it back togther.. rattle free now
1st pic is the reminants of the bumpers
If I can figure the wiring out, the cluster will be used in the Rat.
Name:	busted dash peice.jpg
ID:	45393   Click image for larger version
ID:	45394   Click image for larger version
