-   Hotrodders' Lounge (http://www.hotrodders.com/forum/hotrodders-lounge/)
-   -   can't get project journal to work so heres my rat rod build (http://www.hotrodders.com/forum/cant-get-project-journal-work-so-heres-my-rat-rod-176730.html)
matt167 04-22-2010 04:19 PM
I havn't ever been able to get the project journal to work in Ubuntu linux, and somthing happened to my Windows partition and havn't bothered fixing it, so I havn't updated my project journal....
frame cut
http://www.hotrodders.com/journal_ph...2570245890.jpg
rails welded
http://www.hotrodders.com/journal_ph...2570245911.jpg
http://www.hotrodders.com/journal_ph...2572898470.jpg
welded
http://www.hotrodders.com/journal_ph...2572898481.jpg
matt167 04-22-2010 04:26 PM
cut out the firewall..
http://www.hotrodders.com/journal_ph...2583324240.jpg
removed 6" from the bottom and welded on bottom rail.. 1st welds my new welder welded..
http://www.hotrodders.com/journal_ph...2585008160.jpg
bolted it on ( drilled and tapped frame )
http://www.hotrodders.com/journal_ph...2588396560.jpg
built the lower body framework ( no pics ) and the front window framework
http://www.hotrodders.com/journal_ph...2607267610.jpg
some pics got lost so.. skip ahead and the location has changed to my grandparents garage as it's easier to work around and they suggested it.
http://i42.tinypic.com/33o7aqv.jpg
matt167 04-22-2010 04:29 PM
added rear window framing..
http://i42.tinypic.com/nv2yy1.jpg
cowl tacked in place ( hand formed )
http://i41.tinypic.com/zyikqa.jpg
all the way in.. it didn't go in straight so the rear filler was added
http://i40.tinypic.com/xbix78.jpg
top filler in place
http://i42.tinypic.com/oa54lh.jpg
matt167 04-22-2010 04:36 PM
rear cab wall in place.. I did close up the rear window opening a little
http://i39.tinypic.com/1055v0p.jpg
http://i43.tinypic.com/2hdy0qu.jpg
http://i44.tinypic.com/4kflw5.jpg
lower cowl panels and roof in place
http://i41.tinypic.com/154eeeg.jpg
up on the saw horses getting ready to channel it 6"
http://i42.tinypic.com/28jip2u.jpg
http://i42.tinypic.com/34xq3cy.jpg
6" channel complete
http://i39.tinypic.com/ygi2b.jpg
http://i43.tinypic.com/2vkdjzl.jpg
cboy 04-23-2010 11:39 AM
Way to go Matt.
John(Maynor)Hodgen 04-23-2010 04:09 PM
Looking good and working fast! Will be watching with interest. What kind of bed are you doing? Later--John(Maynor)T.
matt167 04-23-2010 04:34 PM
the bed will be just a basic open top rectangle. probably a little wider than the frame.. it will house the battery and the gas tank, which will be a converted air tank
old fords 04-23-2010 04:37 PM
looks good
matt167 04-27-2010 04:22 PM
3 Attachment(s)
well. I was trying to figure out my P-30 ( Chevy Delivery van ) gauge cluster and I kept hearing ratteling inside the cluster and eventully the glass was loose.. pulled it apart to find what was left of the rubber/ plastic bumpers that held the glass tight... fix was quite easy.. I replaced the plastic bumpers with clear silicone caulk, let it set up for an hour and then put it back togther.. rattle free now
1st pic is the reminants of the bumpers
If I can figure the wiring out, the cluster will be used in the Rat.
matt167 05-13-2010 05:56 PM
little update... the air tank gas tank now has a filler neck welded in.. still no fuel pickup, because I have not made that provision yet
http://i40.tinypic.com/2j19a0z.jpg
