can't get project journal to work so heres my rat rod build - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2010, 04:19 PM
Wiki Edits: 31
I havn't ever been able to get the project journal to work in Ubuntu linux, and somthing happened to my Windows partition and havn't bothered fixing it, so I havn't updated my project journal....
frame cut
rails welded
welded
Old 04-22-2010, 04:26 PM
Wiki Edits: 31
cut out the firewall..
removed 6" from the bottom and welded on bottom rail.. 1st welds my new welder welded..
bolted it on ( drilled and tapped frame )
built the lower body framework ( no pics ) and the front window framework
some pics got lost so.. skip ahead and the location has changed to my grandparents garage as it's easier to work around and they suggested it.
Old 04-22-2010, 04:29 PM
Wiki Edits: 31
added rear window framing..
cowl tacked in place ( hand formed )
all the way in.. it didn't go in straight so the rear filler was added
top filler in place
Old 04-22-2010, 04:36 PM
Wiki Edits: 31
rear cab wall in place.. I did close up the rear window opening a little
lower cowl panels and roof in place
up on the saw horses getting ready to channel it 6"
6" channel complete
Old 04-23-2010, 11:39 AM
cboy's Avatar
Last journal entry: Finished
Way to go Matt.
Always learning...and sharing what I've learned.
Old 04-23-2010, 04:09 PM
Looking good and working fast! Will be watching with interest. What kind of bed are you doing? Later--John(Maynor)T.
Old 04-23-2010, 04:34 PM
Wiki Edits: 31
the bed will be just a basic open top rectangle. probably a little wider than the frame.. it will house the battery and the gas tank, which will be a converted air tank
Old 04-23-2010, 04:37 PM
72 grabber 51F-1 65 chevystang
looks good
Old 04-27-2010, 04:22 PM
Wiki Edits: 31
well. I was trying to figure out my P-30 ( Chevy Delivery van ) gauge cluster and I kept hearing ratteling inside the cluster and eventully the glass was loose.. pulled it apart to find what was left of the rubber/ plastic bumpers that held the glass tight... fix was quite easy.. I replaced the plastic bumpers with clear silicone caulk, let it set up for an hour and then put it back togther.. rattle free now
1st pic is the reminants of the bumpers
If I can figure the wiring out, the cluster will be used in the Rat.
Name:	busted dash peice.jpg
ID:	45393   Click image for larger version
ID:	45394   Click image for larger version
Old 05-13-2010, 05:56 PM
Wiki Edits: 31
little update... the air tank gas tank now has a filler neck welded in.. still no fuel pickup, because I have not made that provision yet
New project? Before turning a wrench, get organized! Centerline Hotrodding Basics 71 03-10-2013 11:29 AM
My First Hot Rod!... project TexasTechX1 Hotrodding Basics 46 04-21-2009 07:40 AM
preplanning a "true" rat rod Shoez Hotrodding Basics 17 12-20-2008 05:15 PM
Rat Rod Project Car Needed dam57 Introduce Yourself 2 10-17-2007 04:32 PM
longest rods in std deck 454 bbc?? deuce_454 Engine 11 01-30-2004 10:06 AM
