Cant get ring gear off the carrier - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2004, 12:40 PM
ChevelleGuy's Avatar
New Member
I am replacing my blown up rear 10 bolt diff carrier and I have taken off all the bolts for the ring gear but it wont budge, I have hit it with a hammer and pried on it and heated it up and hit it but it just wont move. Any Ideas?
Old 08-21-2004, 02:13 PM
BOBCRMAN@aol.com's Avatar
Some are a very tight fit. you may have to use a hydraulic press to remove it. Try hitting it with a large hammer all around the outside edge. Not hitting the same place. It should come loose.
Old 08-21-2004, 05:01 PM
302 Z28's Avatar
Some are real tight. If you have a large brass drift that will help. Just go all around it with the hammer and drift. To get the new gear back on you may have to get several long bolts that fit the thread on the gear. Cut off the heads of the bolts thread them into the gear. This will help you get the gear lined up with the holes in the carrier.
Vince
Old 08-22-2004, 02:24 PM
New Member
I finally got it off by having the bolts in and turned out just a little and hit the tops of them until it moved. Thanks.
