okay a little update. Re adjusted TV cable and topped it off with a little fluid and 4th gear works. I will be getting a new solenoid today at the local shop. Here's where I need help. I just want to know exactly here to put the wires. No brake switch, no vacuum switch, just the wires and a toggle. I will get just the regular two prong on/off toggle. Does ground (D) to the chassis? Then the toggle goes onto the A wire? Like this
