Can't Get Truck To Run - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2004, 10:32 PM
I have changed my fuel filter and the truck won't start. Could there be air in the lines. How do I get my truck to run again?
Old 06-07-2004, 10:34 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
is that all you did?
Old 06-07-2004, 10:40 PM
All I did was change the filter. I thought I had the filter on wrong, but I had replaced it the way it was on. I had tje rear of the truck on ramps could that caused somthing weird to happen?
Old 06-07-2004, 10:43 PM
are you familiar with priming a carb?
i'd try that, could be your fuel pump hasn't filled up the new filter yet. prime it and see if it'll fire.
Old 06-07-2004, 10:46 PM
No I don't. Theres no chapter in the chiltons either. Please help me!!
Also Its A TBI setup. Are there any special tricks to priming the system
Old 06-07-2004, 10:51 PM
remove the air cleaner lid, pour about 1/4 cup of gasoline into the carb, replace the lid, and turn the key. if it still won't start, you have another problem which we'll work on later.
damn. tbi setup.
when you turn the key on to the start position, do you hear the fuel pump make a very slight humm ing noise for a few seconds?
what year, model truck etc?
reason i ask, maybe it has an inertia switch to shut off the fuel pump incase of an accident...... most fuel injected cars have them.
jacking the rear up might have tripped it.
Old 06-07-2004, 10:53 PM
I appreciate the help.
Its an 88 350 C/k 1500
Old 06-07-2004, 11:02 PM
good luck, hope it helps, and let us know whats up?..... i hope its that simple.
Old 06-08-2004, 12:16 AM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
no run?
1st is there fuel in the tank?
2nd undo line at carb
attach a piece of hose into a clean clear container
blow into tank if u use a compressor be careful not to rupture the tank w/ to much pressure use a piece of hose w/ a clean rag to make the seal and blow w/ your mouth is the safest way then u should get some fuel
check for a leaks @ connections
check fuel for water
do not use a cup to pour fuel down the carb get a dawn bottle and clean it out real good and dry
just in case it wants to backfire up the carb
if all that don't work its something else
its one of three things fuel,mechanical or electrical
good luck
"SlowRide66"
"Illegitimis non carborundum"
Old 06-08-2004, 01:34 AM
hmmm's Avatar
Last journal entry: pics
um....r u sure it's a fuel problem to begin with? Have you checked to see if it has spark?
Old 06-08-2004, 06:19 AM
Thanks for all the responses. I got the truck running. Its very frustrating when something like this happens.
Old 06-10-2004, 04:57 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
if it does this to you again in the near future check out the fuel pump.
