Hey guys I need some help today I noticed that when I put the right turn signal on it blinks fine and the left blinker blinks to but very very dim and then when I put the left turn signal the right also blinks but it's noticeable enough to see through the lense also the marker bulbs were blinking too what the hell
Definitly a bad ground back there. Trust me.imp:
Clean the grounds and dont be afraid to solder new ends on them if they look corroded.
Easy to find which one, just grab a 15 foot long piece of wire and hook to the battery negative, then go to the affected lighting while operating the curcuit and touch the substitute ground to the existing ground. When the circuit behaves normally....you have found the defective ground.
I found the bad ground it is the brown wire that grounds the marker lights on the forward light harness it goes from both markers and signal light assemblies to the junction block at the firewall it's tough to trace where that ground ends becausey car has a cage in it so its tough to get under the dash anybody know where that brown wire ends
If I can't trace it to an end I'm just gonna pull it out of the junction block altogether put a ring terminal on it and run it to the body
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
