cant keep motor running? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2008, 11:57 AM
runn141's Avatar
ive got a sbc with an edelbrock carb. i start it up it will run for about 5 seconds and then die. so i figured it was the carb, so i had another on another truck(edelbrock) to see if that was the problem. it does the same thing and it ran perfect on the truck it came from. i managed to set the idle at 3000 rpm to set the timing at 36 degrees but made no difference. 2 carbs, one i know is good, total timing is at 36, what else could it be?
Old 06-02-2008, 12:30 PM
cant keep motor runnig?
try squirting some gas down carb when it starts dieing to see if it keeps running , if so , gas problem .
if it still dies , ignition or stopped up converter , if you have one .
Old 06-02-2008, 01:02 PM
runn141's Avatar
i finally got it to somewhat run with the other carb (#1405) i set the timing by ear at what i think is good right now. i put the other on (#1406) with the choke un hooked and it is way to rich. now that is 2 #1406 carbs, new that has turned out to be junk. and they are supposed to be 2% leaner than the #1405.
Old 06-02-2008, 01:27 PM
T-bucket23's Avatar
Wiki Edits: 26
Sounds like you have a massive vacuum leak
Old 06-02-2008, 04:18 PM
runn141's Avatar
wouldnt the motor try to keep running? with a leak it always tries to stay running when you turn the ignition off.
Old 06-02-2008, 04:56 PM
techinspector1's Avatar
Wiki Edits: 326
This is how a bad rap gets started on a particular carb. The problem is not in the carb, but like T-bucket23 said, is being caused by a vacuum leak. It's YOUR fault, no fault of the carb(s).
Idle the motor as best you can and use a propane torch turned on but with no flame on it. Move the torch tip around the intake manifold and carb base. If the rpm picks up at a particular spot, you've found the vacuum leak. If you can't find it in this way, it means you have a vacuum leak on the bottom of the intake where it bolts to the heads. Air and oil/fuel vapors are being sucked into the intake ports from the crankcase. Pull the intake and go through this procedure to correct it:
http://www.crankshaftcoalition.com/w...ad%2C_internal
Old 06-02-2008, 08:58 PM
runn141's Avatar
they are aftermarket vortec heads and performer rpm air gap intake, all new. are they known to be warped out of the box?
Old 06-02-2008, 09:04 PM
speedydude's Avatar
Registered Cruiser
The manifold could be warped or it could be a problem with the gasket on install. You're just trying to locate a leak if you have one.
