Cant pass emissions 1991 caprice classic - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2010, 07:57 AM
1991 Caprice Classic 132,000
these are the IM240 results
Reading Units Limit Result
HC: 25.9048 GPM 1.2000 Fail
Co: 124.1811 GPM 20.0000 Fail
NOX: 1.6089 GPM 2.5000 Pass
any advice?????
Old 09-16-2010, 03:04 PM
any advice?????
Mixture is way too rich this is causing the high HC number which in turn is causing the CO number as well. The latter because the excess fuel uses up the available oxygen trying to burn all the gas (which it can't) before the chemical reaction of the burn can go to completion which makes the CO into CO2.
- What is the engine?
- Does it have an AIR air injection system that pumps air into the exhaust?
- Has the catalytic converter ever been serviced or replaced?
- When was the last tune up?
- Has the cam timing been checked to see if it still tracks the crankshaft?
- Has a compression or leak down test been performed?
- Has the fuel pressure test at the injector body inlet been performed?
- When was the air filter replaced?
- Does the thermostat work, engine needs to be at least 180 degrees when tested?
Bogie
Old 09-16-2010, 03:13 PM
T-bucket23's Avatar
Wiki Edits: 26
O2 ever been changed?
The numbers show there is both excess unburnt fuel HC and overly rich burnt fuel CO. Looks like the cat is working as the NOX is ok. I would check the operation of the O2 sensors and the MAF if it has one. Also if you have access to a scanner see what the fuel trims look like.
I am guessing your fuel mileage is horrible as well.
One other item is ignition timing. Overly advanced timing will show hight numbers at idle
Edit: Coolant temperature sensor, if it is not working the car will always think it is cold and will dump more fuel than a warm engine needs.
This can also be checked with a scan tool
Chet
1986 Chevy Caprice Classic kringold Body - Exterior 1 07-11-2005 11:12 PM
Parts catalog for a 75 caprice classic hotrodgrasshopper General Rodding Tech 2 07-10-2005 04:26 PM
Wiring 1984 Chevy Caprice Classic kringold Electrical 2 05-30-2005 05:48 PM
LOWERING 75 CAPRICE CLASSIC FASHIONPOLICEx Suspension - Brakes - Steering 4 03-12-2003 12:14 AM
Transmission 81 Caprice classic beetle9 Transmission - Rearend 4 05-09-2002 06:42 AM
