Can't pull my axles - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2004, 12:39 PM
somethin4nothin's Avatar
Can't pull my axles
After placing the car on stands and opening the cover, I can only turn the wheels 1/8th a turn before friction occurs and the wheels become hard to move. I looked at the diff and see that the wheels still turn but nothing is moving on the inside. I disconnected the driveshaft and tried to move the rear by turning the yoke but same thing happens. Looked inside the diff and see that there are only two gears inside. I found a broken gear, but now see that the other is no where to be found. Besides the two parts of the 1 broken gear, I see nothing. Think that the other broken gear is restricting the remaning gears to move? What can I do to turn the diff?
Old 01-14-2004, 04:09 PM
olsixrod's Avatar
Hey SFN, give us a little more info and we'll try to help, make, model, type,posi, locker etc... thanks, Paul
