Can't restart engine Weak spark? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2005, 11:05 PM
Ratchet's Avatar
Last journal entry: Ontario Camaro Nationals 2008
Ok we were having difficulty getting our project car to idle. 383 with big cam 650 demon ported world products heads. So one of the things we decided to try was to use a vacuum can off of a 1977 305. comes it at like 3-5 inches of vacuuum. After installing the vacuum can and a new alternator cause the other one was draining the battery dry when the car was turned off.
Tried to start the engine and give it another round of tunning. Engine cranks and seems to want to fire but it will not start. Checked the coil to the battery wire. Connection is good and there is 13 volts going to the coil.
Tried checking the spark by holding spark plug against ground while still plugged into the wire and cranking the engine. There was no spark in the plug gap. Tried screwdriver in plug wire and holding against ground I got an orange colored spark but I had to hold the wire within a 1/16 or an inch to get it to spark.
Changed cap, Rotor and coil did same test same reults. weak spark.
What do I do next?????
Ric
Old 06-18-2005, 11:17 PM
GoneNova/406's Avatar
have you tried another coil and coil wire.i bought a new coil wire once that drove me nuts til i paid to put it on a machine to find out it was the new coil wire.one minute it was fine and the next it was crappy.or maybe a day later but it always happened.has this motor run in this car before?
Old 06-19-2005, 12:28 AM
Ratchet's Avatar
Yes I tried 3 different coils and another ignition module I had laying around from other vehicles. nothing has changed the problem.
Ric
Old 06-19-2005, 08:57 AM
spinn's Avatar
check your grounds.
look to doc'vettes? grounds thread.
when you pull a plug the is no spark ? correct?
1/16th is like .060+!
Old 06-19-2005, 06:00 PM
Ratchet's Avatar
Where do I find these ground threads I have searched and turn up nothing.
I read someone elses thread that said they were having a hard time starting there engine and they installed hotter plugs and it started right up.
Taking this as a que I changed the spark plugs no change in heat range just fresh clean plugs and yup she started right up.
Ric
Ric
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
Rebuilt Engine Squeaking, Driving me Nuts! BH69Camaro Engine 24 04-22-2005 08:51 PM
Carburator Terrano Engine 10 08-07-2004 11:22 AM
Verifying engine pedigree... johnnya Engine 3 08-04-2004 06:42 PM
