can't run tube inside of tire
I've got one leaking wheel and I asked tire shop if they could use tube and they said they wouldn't put tube inside. Anyone knows of a reason?
Tube......
Hi,i have put tubes in (if there is such a thing) a tubeless wheel,ive never had a problem doing so.
I probably would've done it except Les Schwab refuses to do so, of course they're not my favorite tire dealer, at all. If only I had a tire mounter
Can't the leaking wheel be fixed?
They do sell tubes for radial tires......... Maybe, only certain radials can get tubes.
Ontario Rodders |
I have a set of winter tires on them, chrome is coming off the wheel so it's not sealing well.
Sand and paint the bead area,.........and use bead sealer
Ontario Rodders |
wheel is aluminum/alloy, no need to paint it imo
Well, just clean it up then...it is leaking for a reason....dirt, oxidation, whatever.........and use bead sealer.
Ontario Rodders |
tubeles rims
In the old days the used to say not to run tubeless tires on rivited wheels or you would have slow leakers.
Just a thought....The stem on an inner tube is probably not in the proper place to fit in the stem hole on an aluminum tubeless rim . If it does somehow fit, if anything happened it would be a liability issue for the tire co.
Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
| I Think Someone Doesn't Like Me. (3rd tire problem) | Ghetto Jet | Hotrodders' Lounge | 12 | 05-22-2009 05:15 AM |
| 92 sbc dipstick tube | Eric64 | Engine | 1 | 05-10-2009 03:14 PM |
| Tubing a Tire | 70bird | Suspension - Brakes - Steering | 1 | 08-31-2007 11:35 PM |
| wiring diagram | samh | Electrical | 2 | 02-07-2006 06:28 PM |
| Basic fuse block rewiring | y5e06 | Electrical | 2 | 06-02-2005 06:46 PM |
