Can't see my timing marks! - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2004, 11:17 PM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
Tonight I was trying to check the timing with my timing gun, First it was almost impossible to see the timing marks because of all the belts and pulleys. Plus the angle was really odd, The radiator fan was in also too close for comfort to the back of my hand. Anyone have any tricks to get in there and see?
Regards
Mark
Old 03-30-2004, 12:06 AM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
On certain cars I have used a small mirror (snap on) that you can set the pivoting end to a fixed position and go in from the bottom and use the mirror to reflect the strobe on to the mark. It takes a little getting used to because every thing is backwards. I used it recently on a Continental V6 and a MR2 turbo that were impossible to read from the top because of no access. You still have to be careful not the get the mirror caught in the fan. Wear safety glasses just in case it does so the flying glass doesn't get in your eyes. You may also want to put a dab white paint on the mark on the pulley and the proper mark on the pointer to make it easier to see.
