Can't "shove it on down into overdrive..." - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-29-2011, 06:34 AM
Wiki Edits: 27
2 connections
As noted usually the problem is the connections inside to the terminal I don't have a diagram handy but if I remember right one wire activates the solenoid and the other one is for the ignition interupter circuit. I don't have any spares. I have a w11 Honeomatic Kit on the back end of a C6 I have never installed. was going into my old Ford van but it was parked next to the barn--- fire. took out several cars.
  #17 (permalink)
Old 04-29-2011, 06:44 AM
Wiki Edits: 27
case ground.
The solenoid coil is grounded to the case-transmission.If you don;t have a ground cable to the engine or trans it won't work with the hot to the solenoid.
3 speed maual with auto overdrive Ray Bell Transmission - Rearend 1 09-13-2010 12:59 AM
700R4 or TH400 w/ overdrive 53LEDSLED Transmission - Rearend 8 05-28-2007 08:22 AM
saginaw 4 spd overdrive scatsihc Transmission - Rearend 0 02-05-2006 07:44 PM
4L60E trouble with overdrive Please Help Transmission - Rearend 2 03-19-2004 07:20 AM
Overdrive transmission merkery Transmission - Rearend 1 06-25-2002 09:25 PM
