Can't take the pressure! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2002, 12:55 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Post Can't take the pressure!
What do you guys consider good oil pressure with the stock pump? Hot or cold. Gimmie some clues on oil temp and what causes excessive high temps, What are the effects?, long term?, short term?
Old 09-16-2002, 01:47 PM
drgnwgn289's Avatar
Post
10 pounds of pressure for every 1000 rpm is minimum, but you don't want to go too high, then you will run the sump dry.
Old 09-17-2002, 05:17 AM
Post
What about the oil temps, How high should one let it go?
Old 09-17-2002, 08:14 AM
drgnwgn289's Avatar
Post
I don't know about oil temp, I know that with multigrade oil, it works better when it is warm, but I also know you don't want it to get too hot.....
