Cant turn off winshield wipers.... need help - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2009, 04:02 PM
calimstng66's Avatar
i have a 1966 mustang and the wiper blades cant get them off. i spin the knob and nothing. i just want them off.
Old 10-02-2009, 05:39 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Sounds like you need a switch, Pull a fuse till you get it fixed just hope it don't rain and if it does put the fuse back in. Get a switch should fix it though. JMO..........Cole
Old 10-02-2009, 05:44 PM
did pull the fuse worked like a charm. guess will have to do for now. thanks.
Old 10-02-2009, 07:28 PM
poncho62's Avatar
Wiki Edits: 5
I don't know about Mustangs, but my 62 Pontiac used to do that...There is a little cam in the gearbox that would stick........the cam needed to go around to the home position to shut off,.....needed lubrication.
Old 10-02-2009, 08:49 PM
302 Z28's Avatar
The park cam came to mind when I read it, could be what it is.
Vince
Old 06-05-2010, 08:10 AM
65ELCMO's Avatar
Move to Portland, OR. End of problem
Old 06-05-2010, 10:09 AM
Jake_Dragon's Avatar
Last journal entry: New Carb
Until you can get the correct fix you can do this. In place of the fuse hook up a switch so you can turn the wipers on and off, put the correct fuse in line with the switch. Make sure you get a switch that can handle the power to the wiper motor.
Old 06-05-2010, 12:25 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
First I'd check the park function, as mentioned twice above. If OK, it's very likely the switch.
Old 06-06-2010, 04:00 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
There is power supplied to the wiper motor at all times.
grounding the leads is what makes the wiper go
If not a "park" issue----as I do not recall my 65 having a park feature like the chevies do----it would seem the wirper switch has grounded to itself inside the switch.
the switch should be grounded to the dash and the knob switches the
ground leads from the wiper motor to the body of the wiper switch that is
electrically connected to the dash
Old 06-07-2010, 06:28 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
In the op's case, the "Park" I'm talking about is the circuitry and switch integral w/the wiper motor that causes the wipers to stop only at the bottom of the windshield when the switch is turned off.
69 mustang turn signals dont work GT350 Electrical 3 02-22-2008 04:55 PM
turn signal problem jimang22 Electrical 1 01-03-2008 01:09 PM
Turn Signal jack76 Electrical 2 07-17-2007 06:45 AM
Wiper switch failure ViperMonster800 Electrical 11 05-23-2005 05:13 PM
turn signal blowing flasher fuse RodFather Electrical 12 05-13-2005 07:23 PM
