Capacity for rear end gear oil - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2003, 04:41 PM
Last journal entry: Rear End Disassembly
How much gear oil does a rear end hold, this is an 8 3/4 mopar.
Also, what type or weight should be used for a street/cruiser car?
Old 12-03-2003, 12:45 AM
billman's Avatar
Unless I'm mistaken you need to use SAE 90 weight or 75W-90 gear oil in the rearend. Fill it up until it is on your fingernail when you stick your little finger in the filler hole. The level should be a little below the hole.
