It is possible you can just cut and buff the clear and get rid of the peel.
I use 3m sanding film, starting with 1000 grit and an interface pad on a da. then step up to 1200, then step up to 1500, then 3000 trizac without the interface pad, but using a bit of water to keep the pad wet with the trizac.
Other guys wetsand it by hand using the sme basic steps in grit grade.
Now buff and admire.
