Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Caprice Drive Shaft Length & 8.5" Rear End
Old 12-24-2012, 02:25 PM
LATECH's Avatar
LATECH LATECH is offline
Originally Posted by dwwl View Post
If you're looking at making a real sleeper, put in lower gears in the 10 bolt and a good 700 or 200 4r tranny. That will give you a lower gear ratio for the sleeper and high gear for the road. I'd find that drive shaft and put it aside till your ready for it.
It will sleep allright. A 2.41 with an overdrive...having a final ratio of 0.69 will give an effective final ratio of 1.66. Nothing is gonna pull a gear that tall.
A t 350 or 400 would be Ideal.
If you run an overdrive, you need a 3.55 or lower(3.73 or 4.11) to run it.
Many machine shops a can cut , shorten, phase and weld your shaft probably for 75 or 100 bucks. Get the one you have sliced down and forget it.
Fact is stranger than Fiction
