Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Caprice Drive Shaft Length & 8.5" Rear End
Old 12-26-2012, 01:50 PM
big gear head's Avatar
big gear head big gear head is online now
High Performance Rear Ends
The Eaton Posi uses 4 coil springs, the Trac Lock uses the S shaped spring. The Eaton Posi can have 14, 18 or 22 clutch discs depending on which clutch set is used. The GM Trac Lock uses 14 discs if I remember correctly. Ford Trac Lock uses 14, but only 6 have friction material on them.
You have the corporate 8.5 10 bolt. Some had c clip axles and some didn't, but that doesn't make it a BOP or Chevy, they are all corporate 8.5.
