Frame fit
what you have shown is that the Caprice is about 5" wider than the 39..that is too much to make up with backset..Try an S-10 chassis instead as that is narrower..we try to get within an inch or so of original if possible..
Sorry, OMT
front end on 39
I agree the s10 is a good choice with lots of option on parts. Also the intermediate GM cars Montes , Cutlass, Regals etc should work out too. The s10s and Medium GMs are a dime a dozen around here. Use everything off the donor then junk the body, be suprised all the parts you will use or need. Then you will also have the basic small Chevy pattern wheel bolt patter instead of the larger 5 inch bolt pattern of a truck or big car. Alot more wheels choices or wheels available.
WELCOME YOU HERE....... We have a lot of good members here with a lot of knowledge. The width of the Caprice is too wide........IMHO. WHY the GM only...? ? Ford has the best rear end ( 9 inch ) IMHO.........and Ford brakes are great too. Mix and match... Again.......WELCOME...
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
Well, things are not that simple here. "Medium GMs are a dime a dozen around here" doesn't suit for my "here", because I'm in eastern Europe, Estland (officially estonia). Most widely spread US cars here are Chevy's (Caprice, Van, camaro), other GM fullsizes, mustangs (from '80&up), Lincolns (from '90s), Dodge vans and a lot of FWD cars. Mopar is allmost not represented, not too many trucks of any kind.
Ofcourse here are some cars from any type and year, but they are rare enough to not be used as a donor. I know I will need a lot of parts from donor, that I cannot think of right now, so I'm planning to get a driveable donor. Two s10s are for sale here at the moment, but both are with 2.8 V6 engine. I want V8 or at least R6. Also I guess the V6 and V8 bolt pattern is not the same, so I will need to refabricate engine and trans mounts, when I would like to change it to V8 later. I would prefere a bolt on swap possibility, when thinking of temporary engine. |
Then we need to get a bit more serious...I would suggest that you get some of the chassis books from steve smith autosports and study on making your own crossmember of the correct width using the caprice spindles..I am not sure just what you may wind up using for a rear end in such a circumstance but somethign will turn up I am sure tha tis more available in your part of the world..
There are even some software packages that allow you to evaluate a proposed chassis for roll centers and such..most of that stuff is geared for the circle track racers but it is very applicable to a street rod.. OMT
Lots of info on this site about S-10 frame swaps. I don't think too many people choose to stay with the original powerplant - they only want the chassis and the odds-and-ends that go with it. V8 S-10 swaps are pretty close to a bolt-in, although in your part of the world, it may be a lot less so. |
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| 1954 chevy pickup tilt front end | teach | Introduce Yourself | 5 | 11-30-2004 05:03 PM |
| 62 Chevy aluminum front end | Daniel C Reid | Body - Exterior | 4 | 12-06-2003 12:03 AM |
| My Chevelles Front end, what to do? | bizkit075 | Suspension - Brakes - Steering | 7 | 07-25-2003 06:01 PM |
| front end tilt using my all steel front end | old c10 head | Body - Exterior | 5 | 05-02-2003 01:45 PM |
