I would think the rears would be the same except for diameter, as far as that goes so should the front. The suspension mounting should be the same. I used to pull rear springs and sway bars from GM wagons and use them in 2drs. The springs are shorter free height but when installed the rear rides about 2" higher. I just checked ADDCO's site, sure enough they list different part #s for your generation, rear bars. The fronts listed as the same. On the older gen. they show the same #'s interesting, they must be doing something different on the back. Last edited by 1ownerT; 04-28-2007 at 07:50 AM. |
The 77-90 B-body wagons have a wider rear suspension and axle to allow a 4x8 sheet of plywood to fit flat inside (show me an SUV that can do that!). As a result, the rear suspension and axles are different from those on the sedans. Front suspension is the same.
Next time you see one of these wagons, sight down the side of the car and you'll see how the body flares out behind the back doors. |
| Sway bars, bigger = better? | 69ChevelleAddict | Suspension - Brakes - Steering | 4 | 06-14-2006 05:21 PM |
| Bigger better sway bars?? | Cocacolakidd | Suspension - Brakes - Steering | 5 | 03-28-2006 07:12 PM |
| Model A streetrod sway bars? | joe k | Suspension - Brakes - Steering | 8 | 04-24-2005 11:10 AM |
| sway bars | 36scsc | Suspension - Brakes - Steering | 6 | 02-02-2004 01:40 PM |
| What size of sway bars would be too big? | Dubz | Suspension - Brakes - Steering | 10 | 12-31-2003 03:12 PM |
