caprice vs impala - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-28-2012, 04:23 PM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
the impala SS is nothing more than the cop caprice..
with a sporty gut..
  #17 (permalink)
Old 02-29-2012, 02:12 PM
Mutt's37Buick's Avatar
I'm looking at using a 94-96 Roadmaster engine/trans in my '37 Roadmaster.
1) Can anyone tell me how important it is for me to get a '96 that allows use of the OBDII tool?
2) What is this tool used for?
Thanks
  #18 (permalink)
Old 02-29-2012, 07:15 PM
Vetteman61's Avatar
Last journal entry: Moving my Journal
OBDII is the type of computer used to hook up to the car to diagnose when a check engine light code comes up. That is what the OBDII pertains to. To my knowledge they switched to this type at one time and a certain year of car either would be an OBDII or it would not. I don't think they had a year where some were and some weren't, but I could be wrong.
Brandon
  #19 (permalink)
Old 02-29-2012, 09:32 PM
Brandon,
Thanks for the info. Sounds like it would be worth waiting for a '96.
Mutt
  #20 (permalink)
Old 02-29-2012, 10:12 PM
Vetteman61's Avatar
I don't know a lot about the specifics but this page might help you out:
http://en.wikipedia.org/wiki/On-board_diagnostics
I would check and see, but I would think the 94-96 should all be the same. Once again, however, I could be wrong, but it's worth checking into.
Also, I forgot to add this link. This is extremely helpful and should answer all your questions: http://www.impalassforum.com/vBulletin/index.php
Brandon
  #21 (permalink)
Old 03-01-2012, 09:20 AM
I did find on the buickforums.com that the '96 Buick Roadmaster was the first year was OBDII compatable. Previous years had OBD1.
Obvously these diagnostics are very helpful, but can anyone speak to questions I have:
1) Since the OBDII diagnostics are more capable, do they also add difficulty when performing an engine/transmission swap to a different vehicle?
2) Will I have to also swap more systems from the donor car in order for the engine/transmission to work properly.
3) I had planned on swapping the instruments as well. Would OBDII make this more difficult to swap?
Thanks
  #22 (permalink)
Old 03-01-2012, 09:29 AM
lt1silverhawk's Avatar
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
Brandon
Rumor is that OBD-II was mandatory on '96 and up cars, but the switch was made some time in '95. According to the F-body crowd, it is not unusual to find an OBD-II set up in a '95 LT1-powered car.
Thanks
I would definitely recommend visiting the Impala SS Forum to get more info on the Roadmasters. Lots of knowledgeable guys there. And there is also LT1Swap.com for more general swap info.
  #23 (permalink)
Old 03-01-2012, 09:39 AM
Can anyone tell me if there is a foolproof way to tell if a car has OBDII or OBD1 diagnostics by looking at the car.
Thanks
  #24 (permalink)
Old 03-01-2012, 06:51 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
Thanks
Well an OBD-II system has a specific port in it for identifying codes, where the OBD-I system usually requires you to make a connection with a wire or paper clip in it's diagnostic port and read the CEL Flashes. Though I have a friend with a 95 cavalier that has an OBD-II style port in his car that he claims gives OBD-I codes. FWIW, the port looks like this and is usually found under the dash, drivers side:
  #25 (permalink)
Old 03-01-2012, 08:21 PM
Thanks for your help
Mutt
  #26 (permalink)
Old 11-15-2012, 09:10 PM
OBDII computer in caprice
Brandon
Only the 96 can use the OBDII computer just like all car after that date, I have the factory service manuel for the 91 and 96 caprice.Also the 96 has sensors before and after the cat converters.
  #27 (permalink)
Old 11-15-2012, 10:03 PM
gearheadslife's Avatar
MentalMuffinMan
My friend has an Impala SS and he ordered a front end kit. He swears there's a difference in the way part of the frame up front is shaped on the SS vrs the regular Caprice.
Brandon
he be wrong
