Caps don't want to go on after installing ARP bolts - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2011, 04:36 AM
I have a 454 that we are freshening up after sitting for many years. I rebuilt it completely when I was in high school shop. At that time I left the factory rod bolts. I decided this time to put new ARP this time. It is a 4 bolt forged crank/piston engine so I figured I should. The rod ends were resized less than 500 miles ago. The ARP package says to resize rods hen installing new bolts. Now the caps have a hard time going on. I have not tryed to torqe them to see if that "sets"the bolts in yet but that is my next step. These are 7/16 rod bolts.
Has anyone experienced this?
Do I have to resize?
Will resizing make them go on like factory bolts did?
Thanks for any info.
Old 03-02-2011, 05:30 AM
ericnova72's Avatar
More for Less Racer
If you change the bolts, you have to have the rods resized, as the different bolt will locate the cap slightly different. This is true for either factory bolts or aftermarket bolts. When new bolts are installed it distorts the rod and cap different, making the rod bearing bore no longer round.Tthis is why the package says to install the bolts and then resize the rods, not resize the rods and then change the bolts...
The ARP bolt has a slightly larger knurl on the shank than a factory bolt does, for a tighter fit in the rod and the cap. The caps will end up tighter on the bolts.
Old 03-02-2011, 09:34 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Anytime the bolts are replaced the rods should be checked for size. Most shops will routinely go ahead and resize them all w/o bothering to check them because they're usually out of spec anyway.
You need to put the caps on and torque them to spec after installing the bolts. This will seat them and allow the big end to be measured/checked for size. After doing this the caps will go on easier- even if they still need resized.
I'd suggest using Wave-Loc bolts over the knurled design bolts if you still have a choice.
Old 03-02-2011, 11:01 AM
Thanks, off to the machine shop.
Old 03-02-2011, 02:33 PM
11echo's Avatar
Old Guys Rule!...EVERYTHING!
I've had the rod end re-sized with new rod bolt, and I've had a problem too. For some reason the new rod bolts weren't straight (but not bent)! They were either "pigeon-toed" or "wall-eyed" (out or in) ...all bad but not consistent. I went back to the machine shop and he agreed, but indicated that as long as the cap was on and the rod bolts torqued properly there would be no problem. My issue was I was trying to check bearing clearances with plastic gage and with this "issue" I had to beat on the rod bolts to get the caps off ...so impacting the plastic gage, and effecting the accuracy. SO in the long run I had to just go with what I got, and it worked, but I believe it was poor machining!
Main Caps Bolts wally Engine 9 04-24-2010 06:59 PM
Mixing bolts and studs on main caps Harley Monster Engine 10 01-02-2008 08:08 AM
Installing splayed caps. americanLT1 Engine 6 08-27-2007 09:27 AM
Installing arp rod bolts Eric327 Engine 4 03-10-2007 06:50 AM
Main caps - studs or bolts? camaro80 Engine 6 02-06-2005 12:16 PM
