Captive Nuts or Riv-Nuts? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2012, 04:04 PM
I've got to fit some captive nuts to my chassis front crossmember
Should I weld some nuts to the back of the crossmember, or should I use some rivnuts?
I've only just found out about rivnuts, and whilst I've seen it's possible to buy low profile ones and countersunk ones i'm still concerned that they'll stand out too much from the chassis surface
What does everybody think?
Should I go for welded nuts, or rivnuts, or is there something else I haven't thought of yet?
Thanks
Old 03-20-2012, 05:22 PM
Thanks
I have used a crap load of RIV-NUTs I think they are coolest thing since sliced bread. But I have rethought them. First off, they are aluminum, not the best material to make a nut from (they may have steel ones but the ones I have used are aluminum). So for light stuff, quick mount on sheetmetal that sort of thing I'll still use them. But on a chassis or thicker metal I drill a small pilot hole where the hole is needed. I then weld to the back side of the hole a quarter inch thick piece of metal in the appropriate size, say a 1/2 inch square for a 1/4" bolt. Then using the pilot hole drill it the proper tap size and tap the hole for your bolt. I feel this is the right way to go for anything that is going to carry any weight or vibrate.
I never use nuts, by the time you get good penetration (at least with a mig, maybe a tig would be ok) you are seriously weakening the nut. It makes no sense to me anymore (did plenty of them in the past).
Old 03-20-2012, 05:30 PM
That does make sense
The bit that I'm fitting though is a front grille
It's made of plastic, weighs around 200g, and is held with two bolts
It doesn't have any weight, or need any real strength
The original fitting had two nuts on the back face of the crossmember, but I couldn't see any weld bead anywhere
Old 03-20-2012, 05:42 PM
Steel riv-nuts are available & will hold a lot of weight , they should work well for what you're doing. When you buy a package the spec's are on there, I'd imagine it's on the interweb too??Plus , they can be drilled out & replaced , should the need arise..
dave
Old 03-20-2012, 05:45 PM
Yeah, just done a little googling on them
But I'm still thinking they'll stand too proud from the surface and stop the brackets from fitting flush
Old 03-21-2012, 07:12 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
I use Riv-Nuts a lot (both Aluminum and Steel), but you are correct-they will stand proud about .060 or so-if you have access to the back of the crossmember, you might consider a "nut-plate"-you can use countersunk rivets to hold them, giving you a flush surface-
look here:
https://www.pegasusautoracing.com/gr...D=HARDNUTPLATE
Or, you could use weldnuts-
look here:
http://www.mcmaster.com/#weld-nut-plates/=grbqrb
Fixing Captive Nuts to Fibre Glass ant_8u Body - Exterior 9 02-24-2011 06:10 PM
Nuts samm-i-am Body - Exterior 3 05-28-2010 06:32 AM
Repairing Captive Nuts - Hood Hinge 64Bird Body - Exterior 4 09-08-2009 05:50 PM
Big nuts 78 monte General Rodding Tech 4 03-16-2006 03:20 PM
Nuts........... machine shop tom Off-Topic 18 01-19-2006 01:30 AM
