Capturing water for painting - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-06-2005, 07:33 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Get one of these.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=40211
Considering how much $$$ you spend on piping this and trap's that. You'll be $$$ ahead just getting a drier to begin with.
Big problem in the past was the fact that these were SOOOOO expensive for one with this kind of capacity. But for less than 300,this is a good deal.
  #17 (permalink)
Old 03-06-2005, 08:12 PM
Originally Posted by rick458
Would schedule 80 CPVC pipe work or would it retain too much heat
PVC is crap, plain and simple. It retains heat, just go to galvanized steel pipe.
  #18 (permalink)
Old 03-07-2005, 02:26 AM
rick458's Avatar
Wookie
Thats what I figured, I will get the supplies Tuesday
looks like $50.00 ought to do it
Tomorrow I am going to go shooting with a bud first time in 6 months
and I need to get a money order for an exhaust Manifold for the Z
will 4' laterals with 2' drops work ?
IE leave the compressor run 4' lateral to tee drop 2' and tee to dryer/filter and 25' hose
drop 2' to bleed valve.
continue another 4' lateral from first tee, and drop 2' to drain valve.
  #19 (permalink)
Old 03-07-2005, 02:28 PM
rick458's Avatar
Wookie
I went with 5' laterals 2' drops the sucker is BIG, I still need a 3/4 close nipple
and another 3/4" x 2' and a 3/4"x3/8" reducer and I will be complete
it looks like $80.00 will be the damages and I already had 3 valves for draining
  #20 (permalink)
Old 03-07-2005, 06:14 PM
35prog's Avatar
Last journal entry: More photos
The key is to cool the air, I use a 5 gallon bucket, an extra hose and a moisture trap. I just take the hose comming out of the tank ( i do not have the walls piped yet, and I have painted several cars w/o problems) I coil it in the bucket, dump in ice, hang moisture trap on the side of the bucket and go. It is primitive but it works well.
Putting water in the intake??? 79transam Engine 50 01-10-2006 12:23 PM
another water pump/heater hose question SBC darom Engine 5 11-19-2004 04:26 PM
SB 400 water pump HELP brokenT-A Engine 4 10-08-2004 06:16 PM
Water in Engine billg_69gmc Engine 1 08-24-2004 09:14 PM
water pump heater hose conenction.... oldcarguy85 Engine 3 04-07-2002 09:34 AM
