car 1.5" higher on drivers side - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2004, 04:16 PM
I have a 1966 impala with a ride heighth problem. I put two different sets of drop springs in the front and a new set of rear springs in the rear. Nothing has fixed the problem yet. As far as i could tell there is no binding in the suspension. I installed new shocks all the way around. I had to go buy air shocks to lift the right rear corner of the car to get it to sit level. I swapped the rear shocks in the rear with the same results. The frame is solid and the body mounts are good. Could the bolt that is used to adjust the camber have anything to do with it. Any idea what else it could be?
Old 05-19-2004, 04:29 PM
bonuts's Avatar
Got Ouzo for touzo
Did the car sit wrong before you put in the drop springs? Just thinking, maybe the spring rates are different, or two different size drop springs.
bonuts
