Car Cuts Off If I Take My Foot Off The Gas - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2010, 10:02 AM
My car will stay running as long as my foot is on the gas, the second I take it off. Its stumbles then cuts off. I have noticed gas dripping from the carb squirters when the fuel pump is on and it stops dripping when I turn it off. It also has a major stumble when I press the gas from a dead stop, don't know if all this is related, but I have no clue what is going on.
Old 03-19-2010, 10:11 AM
delawarebill's Avatar
your carb...
u really need to do a rebuild on that carb.. if it dripping when at idle u have a float problem.. and when u start to take off u really load the engine up... pull it apart or get a new one.
Old 03-19-2010, 10:54 AM
techinspector1's Avatar
Wiki Edits: 326
Install a regulator to limit fuel pressure to 5 psi at the carb inlet.
Old 03-19-2010, 11:10 AM
Ugh ...Thats what I was thinking as well either a rebuild or a new one, didn't want to go w/the rebuild because I was planning on getting a new one anyway, but just not right now. Its a Holley 650 double pumper....
I do have a regulator I tried playing w/it some, but it didn't help any is there a way to tell if the regulator is no longer working properly?
Old 03-19-2010, 11:12 AM
DoubleVision's Avatar
Is this the car you did a engine swap on? If so did you block the vapor line that used to go to the carbon canister? if this line is blocked the fuel pressure goes out of control and the carb can`t control it. I already been down this road with my 86 olds cutlass when I made the mistake of blocking the line. Before you go rebuilding the carb check the fuel pressure. If you don`t have a fuel pressure gauge get one. When the fuel pressure gets out of control no matter what carb you put on it won`t stop the flooding.
Old 03-19-2010, 11:16 AM
Yes this is my car, but I can't answer that question for you. I paid someone to swap the old 305 out for the 406. So I don't know I can check, but this is a problem that just started happening this past weekend. If that line was blocked wouldn't that issue have showed up well before now?
Old 03-19-2010, 11:21 AM
I blocked mine when I did the swap in 2000. The problem didn`t start until 2003. Is the carbon canister on the car?
Old 03-19-2010, 11:42 AM
I'm not sure what that looks like, but thinking about what's still in my engine bay. I'm almost certain that its gone.
Old 03-19-2010, 01:08 PM
Put a pressure gauge on it first.If it is the holley regulator that came with an electric pump don't trust it.
Old 03-19-2010, 01:17 PM
If the car is a factory V8 car, then look under the hood on the passengers side frame. You should see a line leading up past the motor mount, the line will be made of steel tubing, this is the vapour line.
Old 03-19-2010, 01:18 PM
I take it that a pressure gauge is different from a regulator?!?!? Its and holley electric fuel put, regulator was bought separately if that means anything.
Old 03-19-2010, 01:22 PM
Yup it is a factory V8 came w/a lil ole 305 oldsmobile motor in it when I first bought it...I'm currently at work, so I can't check it right now, but I will in a few hours or so when I get off. So if I see this line. I'm suppose to unblock it correct?
Old 03-19-2010, 01:38 PM
Surely you understand the difference between a gauge that will tell you what the pressure is and a regulator that determines the pressure.The cheap holley regulators are hit and miss on getting a good one.
Old 03-19-2010, 02:04 PM
Well yea I know the difference, but just not accustomed to putting a gauge on a gas line...I'm use to using it to check air pressures and what not. My regulator was bought separtely from my fuel pump. Its not one that came w/it.
Old 03-19-2010, 02:21 PM
I think you mean a olds 307, Olds didn`t make a 305, chevy did.
My car also came with the 307, the carbon canister was in the passengers side battery tray where your battery for your small block currently sits. So the line will be on the frame on the passengers side, if it`s plugged off, unplug it. This may not fix the problem however, there still could be problems elsewhere, but if the problem is sudden excessive fuel pressure this could be it. I tried everything on mine trying to find a way to run the vapour line to something but I never came up with a good plan until I found a way to run a purge valve to purge the vapour into the air cleaner while the car was running. I never got to use the system because the car was parked before I could. If there`s almost anything you need to know about these cars let me know, I`ve almost did everything you can think of. One piece of advice I can give on them is make sure all the factory grounds are connected. I ran a ground from the battery to the block then another ground from the block to the frame. I used the brake line hold down on the frame as my ground connector. I ran another ground from the intake to the firewall. This greatly helped the electrical system. The headlights got brighter, the voltage gauge didn`t dance around anymore and the car started far easier. There should be a ground coming out of the heater core box on the passengers side, make sure it`s connected also.
Paint and body work warranties ? juggernaut Body - Exterior 12 01-29-2010 07:14 PM
"Basics of Basics" Photographing your car. MARTINSR Hot Rod Art 89 03-31-2009 03:53 AM
First paint scheme for '59 Caddy by me Nightrider Body - Exterior 54 07-05-2005 03:27 PM
"Basics of Basics" Photographing your car. MARTINSR Hotrodders' Lounge 3 06-01-2005 06:25 PM
Story time. Halloweenking Hotrodders' Lounge 17 05-19-2003 11:16 PM
