car dies in park and wont stay started in gear
my car keeps dying in park and in gear. it sounds like it misses to me so i assume it needs to be retimed but i have been told it doesnt need to be by people more experienced than me. Could you give me an idea of what the problem might be?
The car is a 72 nova with 327 that was rebuilt last year. most everything else is stock. |
I just time by ear were it runs best. Making sure it don't ping when I stand on it and starts on one click warm and doesn't kick back on the starter.
Not the ideal method but works for a mild street motor.Would not use this method on a $10K race motor needless to say. |
Alright I will play with the timing and see how it goes. They keep telling me I have to drive the car so I can know what the problem is.
hey thanks big dog that worked pretty good i adjusted the distributor and got the car to stay started in park and in gear but it is still very sluggish and dies if i am not gentle on the gas. i have played with the distributor and it doesnt seem to help. i was reading about some of the problems it could be and have found the distributor could be a tooth off, and carb problems, vaccum problems. what is your opinion?
Have you checked your spark plugs to see if they are not fouled?
i checked the spark plugs and wires and nothing seems out of the ordinary
Are all the vac lines good or plugged off if not used? How good are the spark wires etc? You said it's rebuilt so can we assume everything is new? New carb?
Does it die when you accelerate? Will it stay running if you are easy on the throttle? Float levels good, good fuel pressure, good gas? You really need to know the timing. Could be a simple fix if you're off by a few degrees idle timing did it ever run good and just start going wacky? |
