Car has mental problem? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2013, 04:14 PM
Has anyone experienced this? 1998 Lumina--car starts every time but shuts down after about 2 seconds--is not flooding--is not starving--acts as though the car has been shut off--otherwise when it stays started it runs like new. I have been a shade-tree mechanic for 40 years, has me stumped--computer analysis of no use.. Suggestions anyone?
Old 03-20-2013, 04:21 PM
sbchevfreak's Avatar
Licenced Automotive Technician
Sounds like a PassLock problem to me..... Is the "Theft" lamp flashing when the car starts and dies? Would need a bi directional scanner to monitor the passlock module for intermittant loss of signal. You could try a passlock relearn.... Disconnect the battery for a bit, then reconnect it. Trurn the key to "on", and leave it for minimum 15 minutes. after this time, turn key off, and then try to start the car. Should fire right up.
Old 03-20-2013, 07:38 PM
LATECH's Avatar
X2 with SBCFriek. Look for the flashing theft lamp or security lamp which ever you have.
If it is a passlock system the lockcylinder and tumblers could also be the problem.
Try SBC s suggestion. It may clear it up.
Fact is stranger than Fiction
Old 03-21-2013, 09:29 AM
hcompton's Avatar
Old & Furious
An alarm shop can sell you a box to skip over the gm coded keys if that turns out to be the problem.
Does the fuel pressure fall when the engine shuts off. You may need to hook up a guage and see if the fuel pressure fails as it stalls out. May be the fuel pump or fuel pump relay. They are common to work for a second then crap out when amperage goes up.
Car problem: What could be the cause of these symptoms? CometCyclone Modern Electronic Engines 16 02-24-2012 09:16 PM
Monday's Mental Madness wretched ratchet Off-Topic 3 07-13-2009 09:04 PM
So, when did your wife to be realize you were a mental case when it comes to cars? MARTINSR Off-Topic 15 02-04-2009 02:10 PM
Need help on non car problem!! HemmiGremmie Hotrodders' Lounge 6 06-22-2002 12:07 AM
