car idles 1300 in park 600 in drive why? - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 08-10-2012, 09:36 PM
Greg T's Avatar
www.krusinklassics.net
Originally Posted by 71malibu View Post
how do you adjust the converter and how do you know how when it is adjusted correctly?
thanks
mark
You don't. You buy a converter with a higher stall speed and when you have the proper tune it makes a huge difference. In his case 10* is not enough advance, I don't believe hie is using manifold vacuum port and I still think his converter is too tight.
  #47 (permalink)
Old 09-16-2012, 11:09 PM
Last journal entry: Old guy's low cost Chev coup.
you don't want vacuum at idle. Need to take the timeing advance vacuum from connection above the accelerator valves, so that when they open, they advance the spark. You'll find it hard to set your initial timing if the vacuum advance comes from the manifold, which it will if you connect it to anyplace below the throttle plates. easy nuff to find a connection. open all the vacuum hoses, one at a time, with engine idling, until find one that doesn't change the RPMs when it is open. it will be above the throttle plate, and will create a vacuum when throttle is opened up.
  #48 (permalink)
Old 09-17-2012, 07:30 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The debate on using ported or manifold vacuum has raged for years.
The timing advance curve can almost always be tuned to use manifold vacuum for the vacuum advance- and there are good reasons to do so. In many cases using manifold vacuum will give better throttle response and will allow the curb idle to be set low enough that the transfer circuit isn't being used for supplying idle air/fuel mixture.
BUT in some cases using ported vacuum IS the better choice, like if the cam is big (low vacuum), requiring a large amount of initial timing. Then, using ported would be the preferred way.
Some info here.
  #49 (permalink)
Old 09-17-2012, 07:59 AM
Banned User
i also think the hi-idle/curb idle/choke systems are not tuned right.
If we could get a picture of the carb, this could be very helpful.
SBC knocks up to 1300 rpm, then goes away rattychevy Engine 18 01-25-2012 05:16 AM
1000-1300$ project whatsamotor Engine 4 05-03-2009 06:55 PM
1300 cc vw motor MRGM Engine 6 07-09-2007 06:36 PM
Is this delay from park to drive a big problem on TH350? shockers69 Transmission - Rearend 1 08-02-2004 04:27 PM
Engine wants to die from park to drive Siggy_Freud Engine 4 06-03-2004 11:21 PM
