Car leans to one side - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2007, 11:37 AM
74 pontiac. looking at it from the back, it's got a slight angle to it. Trying to fix it cheaply. Can air shocks fix this? looks like original shocks. any suggestions??
Old 01-17-2007, 11:55 AM
The lean is caused either by chassis damage or by sagging springs. New front coil springs are lass than $100 from your local NAPA, O'Reilly's or CarQuest parts stores. The rear springs may still be available from GM or a Nova specialty store.
Shocks will not affect the set of a body unless they are damaged in the "UP" position of bottomed out and holding up the car from sagging spring or springs.
Old 01-17-2007, 12:19 PM
Thanks! It' gotta be sagging springs. You think changing just one in the front would work? I was told awile back it was caused by some fat ***** like myself driving it for the last 30+ years.(leans lower on driver side) I guess the "correct way" is to change all the springs out.
Old 01-17-2007, 12:40 PM
FordMan1951's Avatar
Ford Man to the bone!!!
Originally Posted by dhomsey
...Can air shocks fix this? ...
Air shocks with separate lines (not both adjusted from one hose.) could level the back. You still might lean when braking because the front springs may be the problem. This would cause braking to suffer. I say replace the springs first. Jack up the rear with a floor jack in the center. If it sits level when jacked up it is the rear springs. Do the same by jacking the front in the center.
Old 01-17-2007, 01:19 PM
OK! i'll do that. thanks! called NAPA front springs for $85 (set) that's in my price.
Old 01-17-2007, 02:16 PM
It definately could be the springs. Possibly the allignment is jacked up a bit, and that could cause it to lean a little to one side also.
Old 01-17-2007, 02:18 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Even if you install 4 new springs it might not sit level if the suspension bushings/ball joints are worn out.
Old 01-18-2007, 07:21 AM
Last journal entry: frame build
Swap the springs side to side if the ride height is still in the acepted range.
sounds odd, but it works.
"Basics of Basics" Photographing your car. MARTINSR Hot Rod Art 89 03-31-2009 02:53 AM
It's all in the details... Nightfire Hotrodders' Lounge 18 09-16-2006 09:53 PM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 07:29 AM
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 09:24 PM
Need color/top ideas.... Cracker Red Body - Exterior 4 09-07-2004 08:14 PM
