i have a 1969 ford falcon
i would like to lower it. How do i do it cheap? |
Cheapest and the most NOT correct way to do it is heat the coils...I'm not even gonna tell you how its done because I hate to see you do it.
2nd cheapest and most common way is to CUT the coils. Later, WEIMER |
Lettign the air out of the tires is the cheapest thing you can do and gains you a good 4".
13" Dayton wires hanging out of the fenders. LOL!!!!! Just kidding. DO NOT torch the springs. Check into dropped spindles or usually you can purchase coil springs with up to a 2" drop thru different aftermarket companies. If you know someone that is a machinist then you can have blocks made for the rear(I think the axle on a Ford is on top of the spring) to lower it. You will have to purchase longer u-bolts. I'm not too familiar with Fords but you may also be able to flip the rear leafs to the top of the shackles if they are now on the bottom.
Kevin |
| Recent Hotrodders' Lounge posts with photos |
