car paint job ,door jam process - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2012, 12:15 PM
hello
i ve seen many time some cars were ready for paint but the door jam , inside truck lid , inside hood , jam betwen fender and door ... all thoses area were paint first
i like the idee , you dont need to deal with open the door for the jam and to have the fender on car for paint , get everything adjust before paint
my wondering is about how to proced
its better to seal the entire car before doing the jam?
or just seal the jam ? and after when im going for the entire car , scuff the overspray and seal the car
im going with a bc/cc paint
thanks a lot
Old 08-03-2012, 01:08 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
I've done it both ways. If your using a 2k sealer I would done the jams frist. If your uasing epoxy as your sealer I would seal do jams then mask them off and suff epoxy with a red scuff pad, tack and paint.
Old 08-03-2012, 02:05 PM
skip99's Avatar
if the doors and trunk are left on, just spray primer with the door open , shut it, and do the car, then sand it all (even the jambs to paint) then spray the car with doors shut, after the cars dries, come back , open doors and trunk, back mask the edges, then mask off around openings, and spray the jambs, it gives a better finish for me, because even if I spray the jambs first and use aperature tape, I still get overspray and dry areas in the jambs. and I end up redoing them anyway,,,,,
Old 08-03-2012, 03:02 PM
i dont quiet understand your way
can you tell me with more detail
im a newbie sorry
thanks
Old 08-05-2012, 12:42 PM
can someone can explain me a little better ? how to get a smooth transition between the jam and the rest of the car if you spray bc/cc at first on the jams
thanks
Old 08-05-2012, 01:11 PM
mitmaks's Avatar
Last journal entry: Grille
My friend Pete shows you how....
Old 08-05-2012, 02:28 PM
thanks
pete...im fan
used to watch his video
but my concern its about the overspray
im doing the jam first , seal and paint
there will be overspray on the exterior
how i proced after , just scuff the overspray , seal over and paint ?
Old 08-05-2012, 03:55 PM
Originally Posted by Vincentnova View Post
thanks
pete...im fan
Mask the exterior around the jamb as well to avoid overspray on the exterior panels.
Old 08-05-2012, 04:06 PM
im going to get a line
how im doing after? sand a little the line ? before paint the exterior
G-body door jam Slant3 Body - Exterior 7 08-01-2006 03:21 PM
door jambs on complete paint job wothrottle Body - Exterior 3 02-05-2006 10:32 AM
door jam prep for epoxy montea Body - Exterior 6 04-11-2005 10:51 PM
A Whole New Paint Job - What's The Correct Process? nightrain_rod Body - Exterior 8 11-30-2003 10:01 AM
