car pulls to the left and sometimes to the right during braking? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2002, 05:36 PM
Post car pulls to the left and sometimes to the right during braking?
why does it altenate sometimes when i brake?
i can understand one direction all the time but what could it mean if it pulls randomly to the right, next time i get in the car it's to the left? etc, etc.
any thoughts?
thanks
b
Old 09-29-2002, 06:10 PM
roys63's Avatar
Post
May be the wheel cyls if they haven't been replaced in a few years or you need the brakes adjusted or the brake hoses, They will check valve, if this stuff is old replace it all Or change it over to disk.
[ September 29, 2002: Message edited by: roys63 ]</p>
Old 09-29-2002, 06:13 PM
72 chevy's Avatar
Thumbs up
Hows the pedal feel? Spongey?..Could be air in the system, does the master cylinder leak fluid?
Old 09-29-2002, 06:15 PM
72 chevy's Avatar
Cool
If Im correct, you have drums all the way around?
Old 09-29-2002, 06:35 PM
Post
yes, drums all the way and i can't afford discs right now.
it feels a little spongy, but it's always felt like that.
i got drums replaced about 10 months ago, it's not leaking either.
Old 09-29-2002, 07:33 PM
Post
Most of the time when the brakes are serviced the flex hoses are not replaced and they end up being on the car for years. If you have recently had your brakes serviced or everything looks good when you inspect it, I'll bet the front flex hoses need replacing and they are not that expensive.
Old 09-29-2002, 08:51 PM
Post
Check the comtrol arm bushings.Loose,worn bushing will cause the caster to change as you brake hard,and epending on which way the road is crowned,or which way the wheel is turned will dictate which way the car will pull.
Old 09-30-2002, 09:02 AM
Post
Are the shoes installed correctly, The longer friction surface toward the rear. If you're not aware there is a long shoe and a short shoe, some people don't know that.
