Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Car shakes in rear?
Old 01-25-2013, 08:17 AM
timothale timothale is offline
Wiki Edits: 27
pinion angle
When getting on the throttle the rear usually squats, changing the pinion angle , Check pinion angle vs trans output shaft angle. adjust the pinion to get it correct.
A wrong length drive shaft from mixing parts ?, Go to inland empire drive shafts and check out their how to for drive shafts.
