car shakes when i shut it off! please help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2004, 12:51 AM
calimstng66's Avatar
this is something new for my car, when i shut off the ignition every once and a while the front of my car (engine, radiator, ext...) will kinda make a funny noise and the car kinda bobbles fron the front. i was thinking maybe it is idiling to fast, please gimmie some info.
Old 05-16-2004, 01:08 AM
malc's Avatar
Born To Be Mild
When you shut off the ignition, does it " run on ?"
That would be a reason for it to shake.
Give some more info on the car, type and age etc.
Old 05-16-2004, 07:09 AM
poncho62's Avatar
Wiki Edits: 5
Timing, idle too high, vacuum leaks.............
Ontario Rodders
Old 05-16-2004, 07:10 AM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
bad gas?
Old 05-16-2004, 09:23 AM
Sudden Psycho 31's Avatar
i agree, need more info.
is it running hot, does it diesel after you turn it off?
you mentioned idle, is it idling too fast, or where you guessing?
did this just start? have you changed anything in the engine recently?
31
Old 05-16-2004, 09:27 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Idling to fast or not giving it time to drop to a low idle.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 05-16-2004, 03:02 PM
it is a 1966 ford mustang 289 no real upgrades on the engine
it does diesel after i shut it off
i believe that it is idiling to fast but it is more of a guess than a forsure thing
just recently started doing this
who knows could be damn expensive bad gas
hope this helps
Old 05-16-2004, 08:34 PM
irocz8868's Avatar
if it is dieseling out it could be timing. the best way to check it would be to take off the dist. cap. put a socket and ratchet on the center bolt of the crank pully. turn the bolt counter clockwise untill you see the rotor button move. then turn it clockwise and see how long it takes for the rotor button to move. if it takes a lot before the button starts moving you may need to replace the timing chain and gear. it could be other things also but that could give you a starting point. hope this helps.
Old 05-16-2004, 08:48 PM
4 Jaw Chuck's Avatar
Tune it up, make sure your spark is perfect and in time, adjust the idle mixture to highest vacuum.
Check the motor mounts, you will need a crowbar to pry the mount up and down to find a fault.
Outlawed tunes from outlawed pipes
Old 05-16-2004, 09:08 PM
troy-curt's Avatar
Troy
Old 05-16-2004, 09:22 PM
Originally posted by crazy larry
bad gas?
Old 05-16-2004, 10:37 PM
Try the cheap & easy stuff first. Try turning your idle speed down just a litte bit & see if it helps.
Old 05-16-2004, 11:30 PM
thanks people i will give it a try in the next few days and will update all
