Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Car shutting off while driving. Help!
Old 05-18-2009, 03:47 PM
worknprogress72 worknprogress72 is offline
I did a load test on the car, ac and stereo on, revved the engine and it was still over 14 volts. Battery is literally 3 weeks old, I tested it and it had over 700 CCA charged. I checked the main grounds under the hood, I will go through and check through the other ones as suggested. I don't believe that it's the ICM, the car would crank easily even while hot, good idea though they go bad all of the time on these styles of engines. Thanks for the suggestions.
