Car sits uneven - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2003, 10:24 AM
Car sits uneven
I'm working on an 88 Thunderbird. After eyeballing and measuring, the rearend is uneven. Right side is higher than left. Rearend has control arms, not leaf springs. I have cut the rear springs to lower (I know most people don't do). Right side still higher. I cut right spring a little more, with same result. Right side still higher 1-1 1/2 inches. How do I even up right side to match left. The left side is the look I'm aiming for.
Old 11-21-2003, 03:23 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
Did you cut both sides intially, or just the one? Also, how old are the springs and was the car sitting for a long time?
If you did cut both springs, how did you do it? If you used heat, or got them too hot while cutting, you may have weakened the left side making it sag.
