Car Skipped than Died? WHY? HLP - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2004, 03:33 PM
calimstng66's Avatar
Let me give you the quick run down. First i drive a 66 mstang. Second, here is how it went down. Two days ago i noticed as i was driving my radio shut for a second than came back on. It did it again the next day. The difference in this time was when the radio came back on my car lost power for a split second. Here is the biggie while waiting for a left turn and a minute after another radio skip, my car completely shut off for about a minute. Please help, what could be the problem.
Old 11-21-2004, 03:45 PM
camaroman7d's Avatar
Could be a lot of things. Ignition switch, starter wire/s would be where I would start my search. Start the car and giggle the keys in the ignition, if it dies or sputters, there's a good chance that's your problem. Double check all wire connetcions to your solenoid. Also check your coil wires.
Royce
Old 11-21-2004, 03:58 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
Well, the problem is you're driving a car around that's about 40 years old expecting original equipment to still do its job!
Gotta go through that car and give it a once-over man, or you can expect a lot of this kinda thing-
K
Old 11-22-2004, 05:30 AM
Check all neg earth (ground ) between eng chass body and any main pos fuses links,,, ya got a bad wire and probably one of those fat suckers,
