Car smells of fuel. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-19-2010, 04:00 PM
Originally Posted by F-BIRD'88
If you need the heater it goes in this water circuit.
Top of water pump to heater, from heater core to drivers side rear manifold port. ( that you would have to add to your manifold.)
Many of the old factory GM manifolds (eg 64-65 corvette 327-375hp fuelie injection manifold) had this rear water port.
(GM eliminated this rear water port on the manifold during the "emissions era" as they wanted a hot(er) running motor at the time.
Many of the edelbrock and professional product manifolds have these rear water ports.
Makes a big difference in idle cooling stability on my 400sbc.
(No more thermostat /temp gauge hunting during warm up.)
more stable/ consistant overall cooling while idling and driving.
Try it.
Yeah I might just give it a go. Although I am running a 160 degree thermostat with two 5mm holes drilled in it, an electric water pump, a 16" electric fan and a decent size alloy raidiator and to date have had no heating problems. It sits between 160 and 180 most of the time and snuck up to 200 in heavy traffic and hot weather. Not bad for a decent cam/compression fresh engine i reckon.
  #17 (permalink)
Old 05-19-2010, 04:20 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Has it back fired through the carb any? If so it could have blown the power-valve. JMO
Cole
  #18 (permalink)
Old 05-19-2010, 10:43 PM
No it has never had a backfire. This engine has started and run sweet since day one. I think the comment about heat soak was probably pretty accurate.
If you do not want to register, fill this field only and the name will be used as user name for your post.
Confessions of an autobody shop owner. How to pick a shop to have your car restored. MARTINSR Hotrodders' Lounge 27 01-29-2010 02:22 PM
hydrogen booster / more mpg hottrodz Engine 39 08-28-2008 02:09 PM
a true story abount my first car chopperdave70 Hotrodders' Lounge 7 01-26-2008 06:13 PM
Carb size to small???? brainsboy Engine 50 08-14-2005 04:04 PM
how would you make it legal?? spooki General Rodding Tech 8 08-31-2003 09:16 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
