car stalls when put in gear after warm up - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2011, 01:52 PM
History,1969 corvette 350/auto.This car was a manual trans car a was converted to auto(Dont ask why)Almost everything in this car is brand new.I got this car because the owner said it wouldn't stay running.It has MSD dist,wires coil,6A box.I just put on a brand new holley 600 4160 carb because that was the only part that wasn't new and looked to be pieced together.First off the choke pulls off way to soon.So I get it running and I keep the idle at about 900 because its running a little lumpy.Don't know if its the cam or something else.stock intake with an adaptor plate.Heres the real problem.Once the car is fully warmed up,If i step on the brake and put it in gear,it drops right out and stalls.When I got the car it was idleing at 1500.That was someone elses fix.Its almost like it has a 800 stall converter or something.Plenty of fuel.what could this be?HELP!!!!!!
Old 07-03-2011, 02:22 PM
DoubleVision's Avatar
Get rid of the adapter plate, those things are nothing but band aides that belong in the trash. They disrupt the vacuum signal, turn a dual plane intake into a single plane because of the open design which causes the idle to run rich because one cylinder is drawing off both idle circuits and not just one.
Next is you need to know the cam specs, if it`s a high performance cam it needs a stall converter. What happens is a large cam`s overlap makes the engine lope at idle, the engine doesn`t have enough low end torque at idle to overcome the drag of the torque converter so it won`t idle. Get rid of the adapter plate then see what it does.
Old 07-03-2011, 02:32 PM
I need the adaptor plate to convert the spread bore intake to a square bore carb.Thats the way the car came.Its going to be very hard to find out cam specs.its been through a few people.I never had a problem like this before.What vacuum circuts are being affected by this?Could a different plate help this?
Oh, it also has a TCI trans converter unknown
Old 07-03-2011, 03:16 PM
Is the intake a stock Quadrajet intake? original for the engine? If so then I think I know what the problem is, let me know soon as you can.
Old 07-03-2011, 05:42 PM
yes its the original rock intake from 69.I don't want to be a parts changer,I'm trying to get this right.I never had a problem like this.This car is a nightmare.It also blew up the water pump taking out the rad,fan,fan shroud.very expensive fix.now I'm stuck trying to figure this out,as this was the original problem.intake swap is not an option.almost all original till the trans swap and this stupid carb swap.I know a lot of you hate the rochester,but I always had no problems with them.
Old 07-03-2011, 05:48 PM
bigdog7373's Avatar
Of course it's fast
Then get an adapter plate that is NOT open in the middle. Also the converter could be shot. As in not spinning freely. Does it look new?
Old 07-03-2011, 06:04 PM
All these parts were installed within the last 6 months.Its a TCI thm350.I'm not sure if they matched the converter to the cam.The car was a 4 speed car and when the current owner wanted it he said he wanted an automatic car so they swapped it.Would a four hole adaptor plate make that much a diff?
Old 07-03-2011, 06:11 PM
Okay, take the carb off, and the adapter, now, look at the carb mounting flange. Right in front of the 2 primary holes, are there 2 small holes right in front of them connected by a trough? Most don`t know what they are, they are the original placement of the heat riser passages from the heads. They were put there to direct the hot exhaust gases into the intake to quickly heat it up to reduce cold start time and eliminating carb icing. It takes a special gasket, metal plate, gasket configuration to cover these holes, as if they are left open the exhaust gas goes freely into the intake manifold. Since it`s exhaust gas it can`t be burned again, it severely dilutes the mixture so badly the engine runs like complete crap no matter how much you tune it.
It also causes alot of mysterious problems that don`t make any sense. It was around 1970 when they redesigned this feature so the exhaust gas went under the intake plenum. If this is a issue you have 2 options, get the correct gasket and a Quadrajet, or get a aftermarket intake such as a edelbrock performer.
Old 07-04-2011, 07:48 AM
how about plugging the holes?
Old 07-04-2011, 10:23 AM
pulled the adaptor plate and yes it has that crossover channel.It was totally blocked off with the gasket.This is crazy, I never had a problem like this before with adaptor plates or intakes or anything like this.
Old 07-04-2011, 11:02 AM
Nice intake.I don't want to keep changing parts chasing this down.Any other suggestions?
Car stalls when warm hot_rod_kid Engine 14 06-18-2009 09:33 PM
Engine stalls in gear azbandit Engine 27 06-29-2008 04:59 PM
383 stalls when put in gear yodert75 Engine 6 04-12-2007 11:02 PM
Stalls when placed in gear 65Guera Engine 2 09-15-2004 11:09 AM
Engine stalls when put into gear 72Nova383 Engine 20 07-25-2004 03:29 PM
