Sure sounds like a bad vacuum leak. Was the carb new or used? What have you done to tune it?
Have someone squirt WD40 around the base of the carb, and other possible leak paths while the engine is idling. If rpm goes up, there is a vacuum peak.
When i had that problem i just adjusted the fast idle screw under the choke. Just pull it all the way to full throttle and it will expose the fast idle screw. Then turn it clockwise to set it up higher. Good Luck!!!!
Hey I was wondering if you guys could tell me if a truck drives for like a few minutes and then dies. But in an hour you can run it again. I was thinking it was the fuel filter or the ignition. The truck is an 89 ford f-150 with a 460. thanks guys, the input from
That sounds like a bad fuel pump.. The gas is what keeps the fuel pump cool and when the fuel pump heats up it might give out... But i would try the filter first...
I'm with willys , Check around the adp. plate and gaskets, something is not right in that area.
Troy __________________ If you don't make mistakes. your not doing anything. 69 ss rs full custom camaro 98 ISCA grandchampion 69 ss rs bb camaro wifes driver 66 Elcamino 350/all dz parts,ac,windows,loaded,my driver 69 ss chevelle bb conv.fresh frame off 26 T sedan street rod |
