car trailer-surge brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2009, 07:23 AM
I have surge brakes (hydraulic) on my car trailer. Does anyone know how to properly bleed them? I do not have a vac. bleeder...is that the only way?
Thanks,
Rick
Old 04-22-2009, 07:43 AM
Last journal entry: Bringing home the 401 Nailhead
My trailer has a lever at the front of the tounge the pushes the rod on the master cylinder. You could have someone work this lever much the same as a brake pedal. Pump and hold while you loosen the bleeder valve. Could do it yourself by holding the lever with a bungi cord.
I have one of the cheaper Mighty Vacs that I loan to those that have a habit of being slow to return. Think it was only about $20.00. Here is a selction that ranges from $29.99 on up. http://www.amazon.com/s?ie=UTF8&keyw...link%5Fcode=qs
Old 04-22-2009, 10:18 AM
powerrodsmike's Avatar
Wiki Edits: 161
Pressure bleeding through the fill port is a good way too. You could always try gravity bleeding, but you'd have to get the tongue a bit higher to make it work.
Do a search here for gravity+bleeding and you'll find some threads about that.
Later, mikey
BE different....ACT normal.
Old 04-22-2009, 01:27 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Take a piece of 1/4" steel plate and glue a piece of sheet rubber as a gasket. Drill a hole in the center and tap it for an NPT air hose fitting. Clamp the steel on to the master cylinder, set your regulator for about 3-5 psi and hook it up. Best one-man bleeding I've ever done.
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 02:32 AM
Car trailer question bluebu Hotrodders' Lounge 9 03-02-2008 09:19 AM
a true story abount my first car chopperdave70 Hotrodders' Lounge 7 01-26-2008 07:13 PM
bagging my car trailer johnsongrass1 Suspension - Brakes - Steering 8 02-24-2007 09:57 AM
Trailer brakes ds-unique General Rodding Tech 3 10-03-2006 06:47 AM
