Car Turns Over But Wont Start - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2009, 04:53 PM
84 Z28 Convertible
Car was running fine a few weeks ago now she turn over but will not start. Its not backfiring or flooding the plugs.
Few things I have check:
1. Engine have fire at plugs
2. Fuel getting into carb
3. Valves have been check over and over again
4. Timing is dead-on
5. Engine has compression
6. fuel pressure 5.5
She just turn over the starter but will not fire. I am confused!
Please help!
Old 12-22-2009, 05:09 PM
001mustang's Avatar
Did you pull plugs to make sure they are not fouled?
Did you try to start with starting fluid?
Old 12-22-2009, 05:13 PM
84 Z28 Convertible
The plugs are clean with no fuel on them. I have not tried starting fluid.
Old 12-22-2009, 05:15 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
What exactly are you working on?
Cole
Old 12-22-2009, 05:21 PM
001mustang's Avatar
I would definitely try starting fluid.
Best to have one person cranking and another person squirting.
If your carb is not tuned/choked perfect it will still start with starting fluid.
Also make sure your choke is not fully closed.
Old 12-22-2009, 06:04 PM
406 bug's Avatar
9.82 @ 139mph
Between the time ir was running fine and the first time it would not start did you do any thing to the vehicle?? if so give details.
Old 12-22-2009, 06:08 PM
84 Z28 Convertible
Cole
84 Camaro, Dart SBC 400, Scat 4340 Crank, Wiseco Piston, Eagle 6"H-Beam Rod, Bullet Solid Cam 275/279,247/251@.050, 565/577-108, AFR-195 Comp, Hooker Super Comp 1-3/4 Headers, Pro-Built 700R4, P.T.C. 3000SS, Strange ENG.12 Bolt 3:73, Holley 750, Edelbrock Air Gap Intake, AFR 195 Heads, MSD Pro Billet distributor w/6AL Box & Balster 2 Coil.
Old 12-22-2009, 06:18 PM
84 Z28 Convertible
I took off the 1" carb spacer and verified the valves setting using EO/IC method.
Old 12-22-2009, 06:32 PM
406 bug's Avatar
9.82 @ 139mph
Look down the carb and make shure throttle plates not hanging up on manifold or carb gasket ; also make shure your shooters are getting fuel into the carb.
Old 12-22-2009, 08:34 PM
84 Z28 Convertible
The butterfly is moving freely and fuel is squitring out into the carb, rotor is fine, I have taken that cap off to reseat it several times. I have spark at the spark plugs. I also double check to make sure it was not 180* out or off a tooth. I moved the plugs on the distributor counter-clockwise one and clockwise one, still nothing. I have watch the spark plug #1 fire while looking at the balancer which came on at about 18*. I am just lost to see why this car will not start.
Old 12-22-2009, 11:32 PM
001mustang's Avatar
If the plugs are dry following start attempts I would consider the possibility that your idle fuel/air is too lean.
Fresh water free fuel?
Wouldn't hurt to verify vacuum while cranking.
Old 12-23-2009, 09:00 AM
T-bucket23's Avatar
Wiki Edits: 26
So since it was running and you have not moved the distributor, the timing should be close enough to run, it ran there before.
The spark at the plugs, is it a nice bright blue or is it yellow.
It may help to try a little fuel in the carb to see if it fires. Maybe something is wrong with the gas you have or maybe someone watered your tank.
I would stay away from ether based starting fluid as it can sometimes fire without spark and can hinder the troubleshooting.
I have also seen bad msd boxes that will give a nice spark but at the wrong time. You may want to see if you can validate the timing with a timing light while cranking.
Chet
Old 12-23-2009, 02:46 PM
84 Z28 Convertible
I may have found the problem. I took of my distributor cap to check my pickup OHMs rating which was 559 and look for any cracks. Everything look good with the naked eye but I can shake the cap while holding the 2 cap screws and something is rattling inside, so I call MSD tech line and they guy said It may be firing at the plugs but not a strong spark to start the engine. I just ordered a cap, rotor, pickup from Summit Racing. Stay Tune...
Old 12-23-2009, 06:45 PM
84 Z28 Convertible
Update:
The distributor cap is not the problem; with the timing light hooked to the number one plug its firing at 21*. I am totally baffled on where the problem lies. Maybe I need to drain the fuel tank to make sure I did not get any bad gas. Everything else seem to be dead on with fuel pressure, compression, and spark.
Old 12-23-2009, 07:13 PM
74vetteman's Avatar
no start
I agree with t bucket, a little fuel down the carb.
If your running a HEI distributor check for a pin hole burnt through the rotor. It will cause an eractic spark and over looked by many people.
(note) have to remove the rotor to check it. look for a small burnt spot on the under side of the rotor.
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Car wouldn't start thismorning topdogger Electrical 15 05-07-2007 05:05 PM
head gasket replacement now car won't start jesse01 Engine 10 04-28-2007 05:53 AM
First paint scheme for '59 Caddy by me Nightrider Body - Exterior 54 07-05-2005 02:27 PM
