Car vibrates when letting off the brake from a stop - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2012, 07:15 PM
valtiel43's Avatar
I have a 1980 Trans Am that runs really good, it has a posi rear with drums in backs, discs in the front and a th350 Trans. Today I was in traffic when I noticed that when I slowly let off the brakes from a dead stop, I'll get to a point where the car will start to vibrate. It's a vibration through the whole car it seems like. If I let off the brakes completely it goes away and I accelerate fine.
I'm thinking maybe torque converter but I really hope not. I'm hoping for a quick fix like brakes or something. I do get a lot of creaking from the rear drums especially if I drive it after it's say for awhile.
Anyone have any clue what's going on?
Old 08-16-2012, 07:29 PM
S10 Racer's Avatar
http://www.warsprints.com
1. Possibly a warped rotor or bad wheel bearing.
2. Maybe a bad tire too.
Old 08-16-2012, 07:30 PM
bigdog7373's Avatar
Of course it's fast
I'd rebuild the rear drum breaks if you havent already. Even if it doesnt solve the problem it needs to be done. The drums in my 78 failed while i was driving, then the fronts about a year later.
Old 08-17-2012, 06:17 AM
Greg T's Avatar
www.krusinklassics.net
Probabaly glazed braking surfaces. If the shoes and pads are still good, remove them all, cut the rotors and drums, use some 60 grit sand paper on the pad/shoe surfaces and reinstall. Use a FLAT surface to cut your pads and shoes. Also, do a quick bedding on the brakes when finished assembling.
Old 08-17-2012, 07:15 AM
T-bucket23's Avatar
Wiki Edits: 26
Vacuum canister issue
Chet
90 Chevy Truck Brake Pedal sinks after stop. pemdj Suspension - Brakes - Steering 13 07-20-2011 08:54 AM
Help please car won't stop raiderdave007 Electrical 6 11-06-2009 08:11 PM
Brake Bleeding-Non Stop Air Bubbles 123pugsy Suspension - Brakes - Steering 16 03-01-2009 02:57 PM
Letting the car sit? "70" Cougar Body - Exterior 4 09-26-2004 10:32 AM
A lot more effort to stop the car after new brake parts were installed? HotRodMan Suspension - Brakes - Steering 8 05-01-2004 02:27 PM
