Car won't start- change in weather? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2006, 10:11 AM
My '72 Pontiac Luxury LeMans has the stock 350 engine with stock rochester 2-bbl and TH350 trans. Although it often doesn't start right away, this morning it didnt start at all. All this summer, with several days of realfeel 105F in a row, the car never failed to start.
I don't know if its because we had our first cool morning in months or what?
I cleaned up the posts on the battery, getting plenty of juice, and the starter cranks fine, engine just won't catch. I don't know if my wife may have flooded it, but starter fluid didnt do the trick as it normally would. I'm pretty sure I'm getting gas coming from the carb...
A few months ago, I changed the vacuum advance on the mid-70's HEI to an adjustable advance unit. Does this thing have to be dialed differently for cooler weather?
Any ideas on whats happening? Bad fuel pump? Choke not engaged or working properly?
Please help, this is my wife's daily driver- I had to borrow a neighbor's truck this morning.
Old 09-12-2006, 10:30 AM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
Are you getting a spark to the plugs?
Old 09-12-2006, 10:32 AM
Jmark's Avatar
You need to verify that it IS getting gas when you push the pedal. If you are, check for spark when cranking. If you are NOT getting spark, or getting a very weak (orangeish/yellow), you need to find the problem. Also, on the older HEI dist's, I used to see the pickup wires break over time due to the vac advance pulling and releasing a few million times. What usually happened then, was it would run ok at idle and cruise but cut out completely as soon as the vac advance pulled the pickup around during a hard acceleration. The circuit would break and kill the ignition.
Going to take some methodical checking and just start with the basics, gas and spark. Might want to pull a few plugs and see if they are soaked too, carb could have taken a dump too.
Mark
Old 09-12-2006, 10:45 AM
If it ran fine all summer the chances are that it is not something broke. The first thing I would do after checking the plugs for gas foul, try to start it and if it doesn't start fairly quickly, take the air cleaner off and have a look where the choke is. If its closed completely, stick something metal in there to prop the choke open a bit and try to start again. I have found quite often with old worn chokes, if they start good in summer, the first cool they close too much and won't start and as it gets colder they will work again. Also there is usually a summer\winter on the spring cover. Try dialing that to get it to work. These checks at least don't cost anything.
Old 09-12-2006, 03:30 PM
T-bucket23's Avatar
Wiki Edits: 26
Probably the choke. If you pump and release the pedal the choke should be closed tight. As soon as the car starts the vacuum pull off will open it up enough to let a little air in until it warms up.
Check the choke first, it is the most likely problem related to temperature. it it appears to be functioning properly then check for spark and fuel.
Old 09-12-2006, 07:41 PM
66Caprice's Avatar
Move It On Over!
I would check for spark first before looking at fuel issues. If you're not getting spark, the HEI ignition module could be bad.
Old 09-13-2006, 11:12 AM
Well, turns out it was all in the choke technique. As in choking my wife for not adjusting her technique for starting the car!!!!
I was left with a flooded mess and little time. Not really her fault, she's not one bit mechanically inclined, just likes to look cool driving vintage rides.
Anyway, I cleaned up the battery terminals, checked out the choke linkage/ cleaned it up a little, and instructed the little lady on how to set the choke on chilly mornings. I only wish I had had the time and battery juice to continue with the trouble-shooting yesterday morning.
Thanks to all who responded. I love it when its the easiest fix first!
Painting roof tips needed..... Bluepen Body - Exterior 7 09-10-2005 10:26 PM
car won't start please help SBC S-10 Engine 4 08-11-2005 09:42 PM
change modular car will start shut off and won't start back up Ramman Engine 1 11-26-2004 09:20 PM
Need color/top ideas.... Cracker Red Body - Exterior 4 09-07-2004 09:14 PM
